moh wave file format
Answered Question
Sep 23rd, 2007
If I want to import wave file to ccm for moh, what wave file format i need? I'm using CCM 4.1(3) sr3a.
Correct Answer by Avner Izhar about 9 years 3 months ago
You can reinstall the system in g711 mode, but that would be a pain ...
So here you go, try the attached and tell me.
Regards, Avner.
Overall Rating: 5 (1 ratings)
Avner Izhar Sun, 09/23/2007 - 21:49
CallManager 4.1(3) has a service that can do this translation for you, it is called 'moh audio translator'.
You should drop the intended moh file in a directory named 'dropmohfileshere' (search for it on the c: drive of a server), the file will be translated and moved to the correct location.
HTH, Avner.
mike.lo Sun, 09/23/2007 - 23:06
however, when i copy ringback.wav from ipccx server and paste into dropmohfileshere folder, i find error in "Music On Hold (MOH) Audio Source Configuration". so, i think it is wrong file format.
mike.lo Sun, 09/23/2007 - 23:38
after i put ringback.wav filr into DropMOHAudioSourceFilesHere folder, i try to input it into MOH audio source configuration of ccm admin. but it pop-up "The MOH Audio Translation Service reported errors while converting the source input file. This source will not work correctly. Please check the input source file and retry the translatio procedure." The source file status shows,
Input File Name: ringback.wav
Error Code:8
Error Text: Unable to transcode file: Unable to connect MOH Encode filter to filter graph
Result: Translation fail
Avner Izhar Mon, 09/24/2007 - 11:06
Your file is probably in g729 format, and callmanager moh audio translator can't handle it.
Try to get a g711 file, that should do the trick.
Let us know, Avner.
mike.lo Mon, 09/24/2007 - 17:00
yes, i know. but where can i find g711 format of ringback.wav?
Correct Answer
Avner Izhar Mon, 09/24/2007 - 17:08
Regards, Avner.
