who can help me with this ACL problem
Sep 23rd, 2007
hi experts,
I have a layer 3 switch and i am trying to accomplish this task: there are two VLAN , supposed VLAN 10 and VLAN 20 , I want PCs in VLAN 10 can ping VLAN 20 but PCs in VLAN 20 can not ping PCs in VLAN 10 , anyone can give me some advises?
thank you!
spremkumar Sun, 09/23/2007 - 22:20
hi
check for Firewalls in the client pc and also for ACLs under the vlans.
if possible do post out the config here.
regds
diablo_mtc Sun, 09/23/2007 - 23:56
thankyou for replying
i am afraid you do not understand what i mean, or maybe i do not express clearly. what i want to do is that PCs in vlan 10 can ping PCs in vlan 20 but PCs in vlan 20 can not ping PCs in vlan 10. just some kind of one direction communication.
aboelhouwers Mon, 09/24/2007 - 01:55
Create an extended incoming access-list on interface vlan 20 with the following entries:
permit icmp any any echo-reply
deny ip any any
aboelhouwers Mon, 09/24/2007 - 04:53
sorry, I meant outgoing access-list: for example
interface vlan 20
ip address
ip access-group out
diablo_mtc Mon, 09/24/2007 - 16:17
how about TCP connections?
Does PCs in VLAN 20 can open TCP/UDP connection to PCs in VLAN 10?
Edison Ortiz Mon, 09/24/2007 - 20:12
ip access-list extended Vlan20_IN
deny icmp [vlan20 subnet] any echo
permit ip any any
interface vlan 10
ip access-group Vlan20_IN
