How to obtain Cisco VPN Client software
Sep 23rd, 2007
Hello, We have a Cisco 827H router which remote clients connect to. One of our users have updated to Windows Vista and would like to use the Cisco VPN Client software so they can connect.
Firstly, does the software work with the 827H using Vista?
Secondly, I am cisco.com registered user, so why am i unable to download the software, as it keeps asking for a login of which i enter is incorrect.
Thank you.
Overall Rating: 5 (3 ratings)
JORGE RODRIGUEZ Mon, 09/24/2007 - 17:50
  • Green, 3000 points or more
Mike, here are couple of links where you can download vpn client for all OS platforms. You will need file access download via cco.
http://www.cisco.com/cgi-bin/tablebuild.pl/vpnclient-3des
http://www.cisco.com/kobayashi/sw-center/sw-vpn.shtml
As far as accessing Cisco file access downloads you would need to contact cisco systems , usually with Smarnet service contract you would have access to file downloads, if you believe you do have that access and cannot download please contact them.
http://www.cisco.com/en/US/applicat/cdcrgstr/applications_overview.html
Jorge
mfreijser Tue, 09/25/2007 - 00:23
  • Bronze, 100 points or more
Keep in mind that there is currently no Cisco VPN Client software for the 64-bit version of Windows Vista. The 32-bit version is supported.
Also: A Cisco VPN Client is a Cisco VPN Client to a router or firewall. It will make no difference for the 827H if the client uses Vista or Windows 98!
Please rate if the post is usefull!
Michael
mike-cisco1 Tue, 09/25/2007 - 03:46
Thanks, just what i needed to know. I only have 1 user which upgraded to vista and is unable to connect to our office due to this, maybe others that will have to update soon also. Is there a way i can register with cisco downloads without having to pay for a registration or something? Thanks
Phillip Remaker Fri, 02/19/2010 - 12:13
  • Cisco Employee,
February 18, 2010
Due to popular demand, the Cisco VPN Client v5.0.7 open beta is now available!
In addition to serving as a general maintenance release, the Cisco VPN Client 5.0.7 beta is compatible with Windows 7 & Windows Vista 64-bit environments.
A 64-bit specific compatible image is available for installation on these platforms.
Please have communicate feedback (both positive and problems) to [email protected].
Key Capabilities available for Beta Testing:
New Platform support – Windows 7 & Windows Vista 64-bit platform compatibility
Software Access: http://tools.cisco.com/support/downloads/go/Redirect.x?mdfid=281940730 (under 5.BETA)
Software is available for download by any customer with a Cisco.com SMARTnet™ enabled login.
Release Notes will be available next week via a link once the download image is selected.
There are currently no plans to support Windows XP 64 bit in the VPN client.
