can't ping 4003 catos switch from my laptop
Sep 23rd, 2007
laptop is in the same subnet as port 2/1 in vlan 1.
I can ping the switch from both laptop windows and the switch. But i can't ping laptop from both laptop windowns nor the switch.
ankbhasi Sun, 09/23/2007 - 22:53
Hi Friend,
Can you check if you have any firewall installed on your laptop which is not pingable. If XP machine it has bydefault firewall enabled.
Ankur
fanli800510 Sun, 09/23/2007 - 23:36
Check your windows sys's firewall. I suspect it block the ping packages.
