1841 Router must accept dial up calls
Sep 23rd, 2007
I have a cisco 1841 router which has a WIC-1B S/T interface.There is an ISDN line terminated here.The telco has given a number for this connection. Now users from another country would be dialing this number and gaining access to a server in the LAN behind 1841. I am familiar with the concept of router dialing a number using username,password,dial-string and dialer-remote name. But how can the router be configured for only accepting dial up calls? I mean the router needs to do no dialing, but only accept incomming calls from a remote location.
Pls help.
Sonu
lgijssel Sun, 09/23/2007 - 23:41
  • Red, 2250 points or more
As long as you do not enter a dialer string in any of the dialer profiles, the router will never dialer outwards.
regards,
Leo
Sonugnair_2 Thu, 09/27/2007 - 06:02
The exact scenario is like this:-
There are people all over the world who would dial into a 1841 router with S/T BRI interface. This dialing in would come from a analog source or from digital sources. Now is this possible and if yes can someone provide some configuration examples.
Pls help as i am very desparate!!
Thx in adavce,
Sonu
ekhoo Thu, 09/27/2007 - 22:26
Sonu,
Call from analogue to your S/T BRI may not work. Normally, you would need a Cisco digital modem MICA or modem WIC-2AM-V2 to terminate your analogue call. However, you could use the AUX port with a normal external dialup modem as analogue dialin connection instead of MICA or Modem WIC.
If the caller is an ISDN router then solution from ?icabrera? should work.
Async Multilink PPP Dialup from Microsoft Windows Clients
http://www.cisco.com/en/US/tech/tk801/tk36/technologies_configuration_example09186a008009455a.shtml
Digital Modem Network Modules
http://www.cisco.com/en/US/products/hw/routers/ps274/products_data_sheet09186a0080091b98.html
regards,
Eng Siong
