Fabric Channel Error
Sep 23rd, 2007
In my 6509 switch I am getting the following error message:
sh logging
Syslog logging: enabled (0 messages dropped, 0 messages rate-limited, 0 flushes,0 overruns)
Console logging: disabled
Monitor logging: level debugging, 0 messages logged
Buffer logging: level debugging, 83 messages logged
Exception Logging: size (4096 bytes)
Count and timestamp logging messages: disabled
Trap logging: level errors, 2 message lines logged
Logging to 202.9.201.116, 2 message lines logged
Logging to 10.120.3.35, 2 message lines logged
Logging to 10.120.3.91, 2 message lines logged
Log Buffer (16384 bytes):
.Sep 23 15:29:26: %CLEAR-5-COUNTERS: Clear counter on all interfaces by wbpo.cwo3 onvty0 (10.120.3.35)
Sep 23 17:13:13: %C6KPWR-SP-4-DISABLED: power to module in slot 1 set off (Fabric channel errors)
00:00:02: BaseBoard Index:156
00:00:02: DaughterBoard Index:208 (Centralized Forwarding Card)
00:00:02: Gemini Rev#: 3
Firmware compiled 29-Jun-07 15:19 by integ Build [100]
00:00:04: %SYS-CFC1-5-RESTART: System restarted --
IOS (tm) c6lc2 Software (c6lc2-SP-M), Version 12.2(18)SXF10, RELEASE SOFTWARE (fc1)
Copyright (c) 1986-2007 by cisco Systems, Inc.
Compiled Fri 13-Jul-07 08:21 by kellythw
*Nov 30 00:00:02.215: CFC1: Currently running ROMMON from S (Gold) region
Sep 23 17:13:56: %DIAG-SP-6-RUN_MINIMUM: Module 1: Running Minimal Diagnostics...
Sep 23 17:14:04: %DIAG-SP-6-DIAG_OK: Module 1: Passed Online Diagnostics
Sep 23 17:14:07: %OIR-SP-6-INSCARD: Card inserted in slot 1, interfaces are now online
Sep 23 17:14:20: %C6KPWR-SP-4-DISABLED: power to module in slot 1 set off (Fabric channel errors)
*Nov 30 00:00:02.231: CFC1: Currently running ROMMON from S (Gold) region
Sep 23 17:15:03: %DIAG-SP-6-RUN_MINIMUM: Module 1: Running Minimal Diagnostics...
Sep 23 17:15:12: %DIAG-SP-6-DIAG_OK: Module 1: Passed Online Diagnostics
Sep 23 17:15:15: %OIR-SP-6-INSCARD: Card inserted in slot 1, interfaces are now online
In slot 1 I have WS-X6724-SFP
Pls suggest.
Thanks in adv.
Overall Rating: 3 (1 ratings)
ankbhasi Mon, 09/24/2007 - 00:09
  • Cisco Employee,
Hi Souvik,
Can you paste the output of "sh fabric error" also have you tried reseating the card into any other free slot to check if error follows?
Ankur
s.mazumdar Mon, 09/24/2007 - 01:23
Thanks for your response. sh fabric error output is given below:
Module errors:
slot channel crc hbeat sync DDR sync
1 0 0 0 0 0
2 0 0 0 0 0
5 0 0 0 0 0
8 0 0 0 0 0
8 1 0 0 0 0
9 0 0 0 0 0
9 1 0 0 0 0
Fabric errors:
slot channel sync buffer timeout
1 0 0 0 0
2 0 0 0 0
5 0 0 0 0
8 0 0 0 0
8 1 0 0 0
9 0 0 0 0
9 1 0 0 0
We have not checked it in other slots. The module is now working fine in slot 1.
But what was the reason of such problem?
Souvik
ankbhasi Mon, 09/24/2007 - 01:39
  • Cisco Employee,
Hi Souvik,
This can happen because of out-of-synchronization condition on the fabric-channel between a particular module and the switch fabric on the supervisor engine in certain circumstances.
The output you pasted make me believe you are not seeing this frequently and can be intermittent one time issue.
Ankur
*Pls rate all helpfull post
s.mazumdar Mon, 09/24/2007 - 02:07
Every thing was working fine. Recently we got this error. Now also it is working well.
Is their any supporting document?
is their any remedy for that?
Souvik
ankbhasi Mon, 09/24/2007 - 02:22
  • Cisco Employee,
Hi Souvik,
I don't have any supporting document for the same handy with me as of now. But this problem as you see is only one time could be at the time of boot there can be some miscommunication between your module and switch fabric which might have reported this message so if it is not coming continuosuly you can ignore it as imtermittent issue.
This is not a serious concern if you see it happening for the first and one time.
Ankur
s.mazumdar Mon, 09/24/2007 - 03:49
This problem didn't happened in time of booting.
The switch was functional. Suddenly the problem happened.
Anything else you can share regarding this?
Souvik
madan.kumar Thu, 04/17/2008 - 01:57
I'm facing a similar issue with WS-X6724-SFP
It says %PM_SCP-SP-2-LCP_FW_ERR_INFORM: Module 12 is experiencing the following error: Interrupt counters cumulative, (10s critical/noncritical)
%C6KPWR-SP-4-DISABLED: power to module in slot 12 set off (excessive interrupt)
We had tried replacing the WS-X6724-SFP and WS-F6700-DFC3B still the same issue persist.We are using 12.2(18)SXF10.
I had attached further details to the msg.
Madan
