Adding node license to CCM5.1 cluster for subscriber
Answered Question
Sep 24th, 2007
How should I add a node license for subscriber server? The CCM 5.1.2 cluster is consisted of 2 servers. The publisher node is licensed and is working ok. Subscriber node is also installed, up and running but I'm not sure should I provide the publisher's or subscriber's MAC address in the licensing procedure?
TIA
Zoran
Correct Answer by anderson-david about 9 years 7 months ago
Hi Zoran,
you need to provide the Publishers MAC address and then put the licence file on the Publisher, ready for your subscriber
I hope this helps
Overall Rating: 5 (2 ratings)
Correct Answer
anderson-david Mon, 09/24/2007 - 04:40
  • Bronze, 100 points or more
Hi Zoran,
I hope this helps
mizoran78 Mon, 09/24/2007 - 07:49
Well, I hope you are right. I'll try this and get back here!
BR
Zoran
Rob Huffman Mon, 09/24/2007 - 04:45
  • Hall of Fame,
    Founding Member
  • Cisco Designated VIP,
    2017 IP Telephony, Unified Communications
Hi Zoran,
The Node License Manager is the Publisher so it is the MAC Address that you provide for any licensing additions/requirements;
Licenses are generated for requested Cisco CallManager nodes (servers in a Cisco CallManager cluster - with seats) and the phones that are associated with those nodes.
Uploading a License file
Use the following procedure to upload a license file to the Cisco CallManager server with the matching MAC address that is provided when requesting for a license file. For information about obtaining a license file see the "Obtaining a License File" section. The Cisco CallManager server where the license file is loaded takes on the functionality of the license manager.
***Note - Upload the license file only on the first node of Cisco CallManager cluster.
Procedure
Step 1 Choose System > License > Upload License File.
The License File Upload window displays.
Step 2 The Existing License Files drop-down list box displays the license files that are already uploaded to the server.
Note Click View File to view the file content of any existing files.
Step 3 To choose a new license file to upload, click Upload License File.
The Upload File pop-up window displays.
Step 4 Browse and choose a license file to upload to the server.
Step 5 Click Upload License File.
After the upload process is complete, the Upload Result file displays.
Step 6 Click Close.
Step 7 In the License File Upload window, the status of the uploaded file displays.
From this good doc:
http://www.cisco.com/en/US/products/sw/voicesw/ps556/products_administration_guide_chapter09186a0080530f9b.html
The Cisco CallManager server where the license file is loaded, assumes the functionality of a license manager.
The license manager serves as the logical component that keeps track of the licenses that the customer purchases and the licenses that customer uses. It refers to the processes that control the checkin and checkout of the licenses. It keeps track of the number of license units that are required for each phone type. The license manager has responsibility for issuing and reclaiming licenses, and detecting whether there is an overdraft of licenses.
http://www.cisco.com/en/US/products/sw/voicesw/ps556/products_administration_guide_chapter09186a0080531ebb.html#wp49438
Hope this helps!
Rob
mizoran78 Mon, 09/24/2007 - 11:03
Thanks guys! I completed subscriber node licensing process successfully!
BR
Zoran
