connecting Cisco VPN client v5 to asa 5505
support.tech
I am having problem configuring remote vpn between ASA5505 and Cisco VPN client v5. I can successfully establish connection between ASA and Vpn client and receive IP address from ASA. VPN client statistics windows shows that packets are send and encrypted but none of the packets is Received/Decrypted.
Can not ping asa 5505
Any ideas on what I have missed?
Try adding...
crypto isakmp nat-traversal
Also, you will not be able to ping the inside interface of the ASA from the vpn without this commmand...
management-access inside
Please rate helpful posts.
mfreijser
Your NAT configuration is incomplete, enter the following commands to your configuration:
access-list nonat extended permit ip 192.168.1.0 255.255.255.0 192.168.0.0 255.255.255.0
nat (inside) 0 access-list nonat
This tells the ASA that the traffic destined for the VPN Client should not be NATted and should be sent directly to the client via the VPN Tunnel!
Please rate if the post helps!
Michael
Hei
Thank you for the help but I can not ping the inside interface on the ASA or local comp in the 192.168.1.0 subnet fron the cisco client
Do you what the problem is?
best regards
Kim
Try adding...
Thanks, for all the help
