snmp traps
Sep 24th, 2007
Hello:
I want to disable de snmp traps for linkup/linkdown in my 6500. I can only to choose between authentication and warmstart. How can I do?
I want also disable snmp-server enable traps slb, but after the no command the trap is enable again. Why?
thanks for your answers.
Antonio
Overall Rating: 2 (2 ratings)
David Stanford Mon, 09/24/2007 - 05:11
  • Cisco Employee,
Can you try no snmp-server enable traps snmp linkup linkdown?
Also, you may not have snmp server traps slb on your device in that code.
aherraez77 Mon, 09/24/2007 - 23:34
I can?t write snmp-server enable traps snmp linkup linkdown. The invalid input message is the answer from the router.
David Stanford Tue, 09/25/2007 - 05:23
  • Cisco Employee,
Please send the output of:
snmp-server enable traps ?
aherraez77 Tue, 09/25/2007 - 05:56
Hello:
the output is:
(config)#snmp-server enable traps snmp ?
authentication Enable authentication trap
warmstart Enable warmStart trap
(config)#snmp-server enable traps ?
atm Enable SNMP atm traps
bgp Enable BGP state change traps
casa Enable SNMP casa traps
chassis Enable SNMP chassis traps
config Enable SNMP config traps
dlsw Enable SNMP dlsw traps
entity Enable SNMP entity traps
frame-relay Enable SNMP frame-relay traps
hsrp Enable SNMP HSRP traps
isdn Enable SNMP isdn traps
module Enable SNMP module traps
rsvp Enable RSVP flow change traps
rtr Enable SNMP Response Time Reporter traps
slb Enable SNMP SLB traps
snmp Enable SNMP traps
vtp Enable SNMP VTP traps
the IOS's version is:
IOS (tm) c6sup1_rp Software (c6sup1_rp-PSV-M), Version 12.1(11b)E4, EARLY DEPLOYMENT RELEASE SOFTWARE (fc1)
Can be a version's trouble?
thanks
David Stanford Tue, 09/25/2007 - 06:24
  • Cisco Employee,
Now please send the output of
also, notice above that you do in fact have the option for slb traps. If you tried to disable them and it did not work, then they were not enabled.
Martin Ermel Tue, 09/25/2007 - 07:15
  • Blue, 1500 points or more
Is you cat6k running in hybrid mode? so you have both, IOS for the routing engine and CatOS for the switch?
If it is (as I assume) you should login to the switch (CatOs) to control link up/down messages.
this is the command on CatOS to control traps and syslogs for link up/down messages.
set port trap enable
set port trap disable
David Stanford Tue, 09/25/2007 - 09:39
  • Cisco Employee,
Looks like this is IOS, not CatOS.....but he should still be able to do this both globally and per interface/port basis
yjdabear Tue, 09/25/2007 - 09:44
  • Gold, 750 points or more
What's the lowest IOS code level that has per-interface linkUp/Down trap control?
aherraez77 Tue, 09/25/2007 - 09:59
Hello:
finally I have writed the interface-command:
no snmp trap link-status
I think that is impossible make it in global configuration.
thanks everybody por the answers
antonio
David Stanford Tue, 09/25/2007 - 11:12
  • Cisco Employee,
It is still possible globally...if you can post snmp-server enable traps snmp ? we can see what you have
aherraez77 Tue, 09/25/2007 - 23:10
Hello:
the output is:
