Gateway hardware for UK PSTN
Sep 24th, 2007
I have a test setup and am having the classic problems with FXO connections. I would like to verify my hardware suitability before I go any further...
Could any one who has a working system in the UK using analogue lines confirm (or deny) that the hardware below will (when properly configured) correctly connect to the standard BT PSTN and handle connections/disconnections properly?
If anyone with such a working config could give me the results to the following command that would also be much appreciated;
sho voice port
The CallManager server appears fine internally, it just if my gateway as detailed below will do the job;
Cisco 2611 Router
IOS (tm) C2600 Software (C2600-IS5-M), Version 12.3(10a), RELEASE SOFTWARE (fc2)
ROM: System Bootstrap, Version 11.3(2)XA4, RELEASE SOFTWARE (fc1)
System image file is "flash:c2600-is5-mz.123-10a.bin"
cisco 2610 (MPC860) processor (revision 0x203) with 61440K/4096K bytes of memory.
Bridging software.
X.25 software, Version 3.0.0.
1 Ethernet/IEEE 802.3 interface(s)
4 Voice FXO interface(s)
32K bytes of non-volatile configuration memory.
16384K bytes of processor board System flash (Read/Write)
Voice cards (via NM-2V)
VIC-FXO-M2
Any suggestions would be much appreciated.
