5510 not handing out IP's to ASA 5505
Sep 24th, 2007
Good Morning NetPro Community,
I'm new to configuring the 5510/5505 for VPN. I have the VPN nailed up between the 5505 and 5510, but I can't get the 5510 to hand out IP's to the 5505. Any ideas what I'm missing? My config for the 5505 is below. I will paste the 5510 config in my next post due to character limit. Any help would be appreciated!!! I'm banging my head up against the wall on this;-)
5505 Config:
ASA Version 7.2(2)
hostname ciscoasa
domain-name default.domain.invalid
encrypted
names
interface Vlan1
nameif inside
security-level 100
ip address 10.80.0.1 255.255.255.0
interface Vlan2
nameif outside
security-level 0
ip address dhcp setroute
interface Ethernet0/0
switchport access vlan 2
interface Ethernet0/1
interface Ethernet0/2
interface Ethernet0/4
interface Ethernet0/5
interface Ethernet0/6
interface Ethernet0/7
passwd xxx
ftp mode passive
dns server-group DefaultDNS
pager lines 24
logging asdm informational
mtu inside 1500
mtu outside 1500
icmp unreachable rate-limit 1 burst-size 1
asdm image disk0:/asdm-522.bin
no asdm history enable
arp timeout 14400
global (outside) 1 interface
nat (inside) 1 0.0.0.0 0.0.0.0
timeout conn 1:00:00 half-closed 0:10:00 udp 0:02:00 icmp 0:00:02
timeout sunrpc 0:10:00 h323 0:05:00 h225 1:00:00 mgcp 0:05:00 mgcp-pat 0:05:00
timeout sip 0:30:00 sip_media 0:02:00 sip-invite 0:03:00 sip-disconnect 0:02:00
timeout uauth 0:05:00 absolute
username ntta password ZhOtHfugWPDCYwqX encrypted privilege 15
http server enable
no snmp-server location
no snmp-server contact
snmp-server enable traps snmp authentication linkup linkdown coldstart
telnet timeout 5
ssh timeout 5
console timeout 0
dhcpd auto_config outside
vpnclient server 129.250.40.240
vpnclient mode network-extension-mode
vpnclient nem-st-autoconnect
vpnclient vpngroup ErikVPNHardwareClient password ********
vpnclient username ehoehne password ********
vpnclient enable
class-map inspection_default
match default-inspection-traffic
policy-map type inspect dns preset_dns_map
parameters
message-length maximum 512
policy-map global_policy
class inspection_default
inspect ftp
inspect h323 h225
inspect h323 ras
inspect rsh
inspect rtsp
inspect esmtp
inspect sqlnet
inspect skinny
inspect sunrpc
inspect xdmcp
inspect sip
inspect netbios
inspect tftp
service-policy global_policy global
prompt hostname context
Thanks!
Erik
erikhoehne Mon, 09/24/2007 - 05:54
Here's the 5510 Config. Please keep in mind the 5510 has a VPN configured to our Nokia FW as well. 10.80.0.0/24 is what I'm trying to send to the 5505. That traffic will then be sent to our Nokia when going to the 129.250.161.0/25 network. I'm trying to get that working too;-)
5510 Config:
nameif outsideinterface
security-level 0
ip address 129.250.40.240 255.255.255.224
same-security-traffic permit intra-interface
object-group network TelcoNetwork
description Signaing Server Network Space
network-object 129.250.161.0 255.255.255.128
access-list outsideinterface_nat0_outbound extended permit ip any 10.80.0.0 255.255.255.0
access-list management_nat0_outbound extended permit ip 10.80.0.0 255.255.255.0 object-group TelcoNetwork
access-list outsideinterface_1_cryptomap extended permit ip 10.80.0.0 255.255.255.0 object-group TelcoNetwork
access-list outsideinterface_cryptomap_65535.65535 extended permit ip any any
ip local pool HardwareClientPool 10.80.0.0-10.80.0.255 mask 255.255.255.0
global (outsideinterface) 1 interface
nat (outsideinterface) 1 10.80.0.0 255.255.255.0
route outsideinterface 0.0.0.0 0.0.0.0 129.250.40.254 1
timeout xlate 3:00:00
dynamic-access-policy-record DfltAccessPolicy
crypto ipsec transform-set ESP-AES-256-MD5 esp-aes-256 esp-md5-hmac
crypto ipsec transform-set ESP-DES-SHA esp-des esp-sha-hmac
crypto ipsec transform-set ESP-DES-MD5 esp-des esp-md5-hmac
crypto ipsec transform-set ESP-AES-192-MD5 esp-aes-192 esp-md5-hmac
crypto ipsec transform-set ESP-3DES-MD5 esp-3des esp-md5-hmac
crypto ipsec transform-set ESP-AES-256-SHA esp-aes-256 esp-sha-hmac
crypto ipsec transform-set ESP-AES-128-SHA esp-aes esp-sha-hmac
crypto ipsec transform-set ESP-AES-192-SHA esp-aes-192 esp-sha-hmac
crypto ipsec transform-set ESP-AES-128-MD5 esp-aes esp-md5-hmac
crypto ipsec transform-set ESP-3DES-SHA esp-3des esp-sha-hmac
crypto dynamic-map SYSTEM_DEFAULT_CRYPTO_MAP 65535 match address outsideinterface_cryptomap_65535.65535
crypto dynamic-map SYSTEM_DEFAULT_CRYPTO_MAP 65535 set pfs
crypto dynamic-map SYSTEM_DEFAULT_CRYPTO_MAP 65535 set transform-set ESP-AES-128-SHA ESP-AES-128-MD5 ESP-AES-192-SHA ESP-AES-192-MD5 ESP-AES-256-SHA ESP-AES-256-MD5 ESP-3DES-SHA ESP-3DES-MD5 ESP-DES-SHA ESP-DES-MD5
crypto map outsideinterface_map 1 match address outsideinterface_1_cryptomap
crypto map outsideinterface_map 1 set pfs
crypto map outsideinterface_map 1 set peer 129.250.40.241
crypto map outsideinterface_map 1 set transform-set ESP-3DES-SHA
crypto map outsideinterface_map 65535 ipsec-isakmp dynamic SYSTEM_DEFAULT_CRYPTO_MAP
crypto map outsideinterface_map interface outsideinterface
crypto isakmp identity address
crypto isakmp enable outsideinterface
crypto isakmp policy 10
authentication pre-share
encryption 3des
hash sha
group 2
lifetime 3600
crypto isakmp policy 65535
encryption 3des
hash sha
group 2
lifetime 86400
threat-detection basic-threat
threat-detection statistics access-list
group-policy ErikVPNHardwareClient internal
group-policy ErikVPNHardwareClient attributes
dns-server value 10.51.200.251 129.250.161.8
vpn-tunnel-protocol IPSec
split-tunnel-policy tunnelall
nem enable
encrypted privilege 0
username ntta attributes
service-type admin
username ehoehne attributes
vpn-group-policy ErikVPNHardwareClient
tunnel-group ErikVPNHardwareClient type remote-access
tunnel-group ErikVPNHardwareClient general-attributes
address-pool HardwareClientPool
default-group-policy ErikVPNHardwareClient
tunnel-group ErikVPNHardwareClient ipsec-attributes
pre-shared-key *
tunnel-group VPNToDallasFW type ipsec-l2l
tunnel-group VPNToDallasFW ipsec-attributes
pre-shared-key *
Erik
erikhoehne Mon, 09/24/2007 - 11:44
I just noticed I have an IP on the VLAN 1 interface; please ignore that. I hardcoded that on there to troubleshoot.
kelvindam Sat, 09/29/2007 - 02:00
Your client 5505 is running in Network Extension mode. So the 5505 is assuming that his own network is to be used as remote net, and not expecting a dhcp address.
Kelvin
erikhoehne Mon, 10/01/2007 - 06:51
Good Morning Kevin,
Ahhhhh; I see. Wow, I thought NEM was what is needed. I figured it was something simple I was doing wrong. Let me give this a try.
Thanks for the response!!
Take Care,
Erik
