Does inserting a WIC-1DSU-T1 into 3745 require reboot?
Answered Question
Sep 24th, 2007
One of my 6 WIC-1DSU-T1 failed on the 3745 router. I have the replacement WIC-1DSU-T1 and would like to insert into my 3745. Will I need to reboot for the router to recognize the new wic?
Correct Answer by Kevin Dorrell about 9 years 7 months ago
WICs are not hot-swap. You may even damage the new WIC if you do not power down.
Kevin Dorrell
Luxembourg
Overall Rating: 5 (1 ratings)
Correct Answer
Kevin Dorrell Mon, 09/24/2007 - 05:53
  • Green, 3000 points or more
Kevin Dorrell
Luxembourg
