CSM Sticky Group or predictor command?
Sep 24th, 2007
i want to ensure that my client connections are connecting to the same real server as long as it is inservice. When it goes down a second server will take this job. Question: Is it possible to reach that goal by using a parameter in the predictor or weight command, or is it solely required to configure a sticky group?
Thanx, Stephan
Overall Rating: 4 (2 ratings)
diro Mon, 09/24/2007 - 22:17
  • Bronze, 100 points or more
If you do not need to loadbalance i would suggest to do a vserver with one serverfarm that has one server and assign to that serverfarm a sorry/backup serverfarm with one server
rp(config-slb-vserver)#serverfarm black-red backup green-blue
