WS-G5483 is not able to trunk between switches
d.worthley
I have a WS-C3524-XL with a WS-G5483 in Gi0/1 and it is connected to WS-C3750-24P via 10/100/1000BaseTX SFP and I am not able get a Dot1q trunk up between the switches. The WS-C3750-24P shows connected but the WS-C3524-XL show not connected.
7 Replies 7
amdil
can you give us some detail about trunk configuration(sh int trunk, sh in gi0/1)
BR. Amdil
The 3750 is configured with the following:
interface GigabitEthernet1/0/2
description CAT3524 Gi0/1
switchport mode trunk
The 3524 is configured with the following:
interface GigabitEthernet0/1
description CAT3750 Gi1/0/2
The 3750 is showing connected and the 3524 is showing not connected.
There is no information about trunked vlans.
Moreover all trunked vlans should be added to vlandatabase.
BR. Amdil
Right and I have them added.
The trunk is defaulted to allow 1-1005 vlans which are included in the vlan database.
Since switchport trunk allowed 1-1005 is default it will not show up in the configuration.
You didn't mention about vlan's no. so I asked.
Please, let me know the output from the following commands:
cat3750 & cat3524
sh int Gi1/0/2 ; sh int gi0/1
sh int tru
BR.Amdil
cat3750#sh int Gi1/0/2
GigabitEthernet1/0/2 is up, line protocol is up (connected)
Hardware is Gigabit Ethernet, address is 0014.6a1e.5402 (bia 0014.6a1e.5402)
Description: CAT3524 Gi0/1
MTU 1500 bytes, BW 1000000 Kbit, DLY 10 usec,
Keepalive not set
Full-duplex, 1000Mb/s, link type is auto, media type is 10/100/1000BaseTX SFP
input flow-control is off, output flow-control is unsupported
Last input 00:11:25, output 00:00:00, output hang never
Queueing strategy: fifo
Output queue: 0/40 (size/max)
5 minute output rate 3000 bits/sec, 5 packets/sec
1071 packets input, 86556 bytes, 0 no buffer
Received 1017 broadcasts (0 multicast)
0 watchdog, 1006 multicast, 0 pause input
6131 packets output, 567933 bytes, 0 underruns
0 output errors, 0 collisions, 1 interface resets
CAT3524#sh int gi0/1
GigabitEthernet0/1 is down, line protocol is down
Hardware is Gigabit Ethernet, address is 0007.50a6.f919 (bia 0007.50a6.f919)
Description: CAT3750 Gi1/0/2
Keepalive not set
Full-duplex, 1000Mb/s, media type is T
output flow-control is off, input flow-control is off
Last input 2d05h, output 00:11:58, output hang never
Output queue 0/40, 0 drops; input queue 0/75, 0 drops
75 packets input, 842488 bytes, 0 no buffer
Received 64 broadcasts, 0 runts, 0 giants, 0 throttles
0 watchdog, 12 multicast, 0 pause input
73 packets output, 8703 bytes, 0 underruns
0 output errors, 0 collisions, 26 interface resets
0 lost carrier, 0 no carrier, 0 pause output
cat3750#sh int tru
Port Mode Encapsulation Status Native vlan
Fa1/0/10 on 802.1q trunking 10
Fa1/0/11 on 802.1q trunking 10
Gi1/0/2 on 802.1q trunking 1
Port Vlans allowed on trunk
Fa1/0/10 1-4094
Fa1/0/11 1-4094
Gi1/0/2 1-4094
Port Vlans allowed and active in management domain
Fa1/0/10 1-3,5,7,10,100,192,210
Fa1/0/11 1-3,5,7,10,100,192,210
Gi1/0/2 1-3,5,7,10,100,192,210
Port Vlans in spanning tree forwarding state and not pruned
The trunk configuration is OK.
You have a problem with physical connection.
("GigabitEthernet0/1 is down, line protocol is down")
Check your GBIC and particularly cable.
BR.Amdil
