Is a Cisco 877 simlar to the Cisco 837 to configure?
Sep 24th, 2007
I'm upgrading a Cisco 837 to a 877 for our remote VPN. I've heard this router would be better for through put as it's specs are much better. I'm going to order it, but will the configs be similar?
Paolo Bevilacqua Mon, 09/24/2007 - 08:00
  • Hall of Fame,
    Founding Member
Yes. Don't bet that it will improve perceived performances, however.
whiteford Mon, 09/24/2007 - 08:44
Well I hope it will, I've been told the 83x series routers are low budget, we have a site to site VPN using one and the cpu can hit 95% quite easily, apparenty due to the 837 not being able to handle the encryption. Plus they can only handle 2-3mb ADSL lines. I've ordered a 877 and 1841 with an ADSL card to do some tests. Apparently they can handle much more through put.
Paolo Bevilacqua Mon, 09/24/2007 - 10:45
  • Hall of Fame,
    Founding Member
Let us know how it goes!
whiteford Mon, 09/24/2007 - 11:00
Only if goes well or my anger will be shown to the routers ;)
