IPS event query ** Help needed badly**
Sep 24th, 2007
Greetings all. Apologies for the dramatic headline but I'm in a bit of a time crunch.
I have a 4215 running 6.0(3)E1. The device is inline. Below is an event which triggered,
evIdsAlert: eventId=1184881408377311643 severity=low vendor=Cisco
originator:
hostId: xyz
appName: sensorApp
appInstanceId: 380
time: 2007/09/24 15:11:25 2007/09/24 15:11:25 UTC
signature: description=Recognized content type id=12673 version=S149
subsigId: 0
sigDetails: Recognized content type
marsCategory: Info/Misc
interfaceGroup: vs0
vlan: 0
participants:
attacker:
addr: locality=any a.a.a.a
port: 80
target:
addr: locality=any b.b.b.b
port: 51095
os: idSource=unknown relevance=relevant type=unknown
actions:
deniedFlow: true
context:
fromAttacker: <stuff>
riskRatingValue: attackRelevanceRating=relevant targetValueRating=medium 50
threatRatingValue: 15
interface: fe2_1
protocol: tcp
I have an external application which pull this same event from the sensor using a query *like* the following,
wget --user foo --password hoo http://a.b.c.d/cgi-bin/event-server?events=evAlert
I'm able to pull most of the event information but not all. What I can't seem to get from query is the " deniedFlow: true" value. I'm seeing something like,
></attack></participants><actions></actions></evAlert>
Notice the "deniedFlow: true" information missing between action.
Is my wget-ish query missing some arguments which is preventing me from pulling all the same information I can see from the CLI?
Thanks in advance.
gdntsoc Mon, 09/24/2007 - 07:55
That solved it. Thank you very much, James. I appreciate it.
