SelectCmDevice problem (CCM5)
Sep 24th, 2007
I use "AXL Serviceability API" and I have some problem on CCM5. I use
SelectCmDevice.
CCM5 returns ERROR:
<axl:code>5003</axl:code><axl:message>No Handler found for
SelectCmDevice</axl:message>
I try the SelectCmDevice-query on CCM4 and CCM4 works fine and result is
correct.
What I must run/select/stop in CCM5? AXL and SOAP services was started.
Thanks in advanced
Andrea
