Callmanager 6 : Recover Lost Security Password
Sep 24th, 2007
Does anyone knows how to recover a lost admin security password in CallManager 6.0 ?
The commande would be in CLI "set password security".
But I can't remember the actual password so I can't change it.
Thanx,
Bastien.
Overall Rating: 5 (2 ratings)
rob.huffman Tue, 09/25/2007 - 06:46
Hi Bastien,
This was provided for CCM 5.x by Mahesh but may apply to 6.x as well;
Recovering the Administrator Password
If you lose the Administrator password and cannot access the system, use the following procedure to reset the Administrator password.
Note During this procedure, you will be required to remove and then insert a valid CD or DVD in the disk drive to prove that you have physical access to the system.
Procedure
Step 1 Log in to the system with the following username and password:
Username: pwrecovery
Password: pwreset
The Welcome to admin password reset window displays.
Step 2 Press any key to continue.
Step 3 If you have a CD or DVD in the disk drive, remove it now.
Step 4 Press any key to continue.
The system tests to ensure that you have removed the CD or DVD from the disk drive.
Step 5 Insert a valid CD or DVD into the disk drive.
The system tests to ensure that you have inserted the disk.
Step 6 After the system verifies that you have inserted the disk, you get prompted to enter a new Administrator password.
Note The system resets the Administrator username to admin. If you want to set up a different Administrator username and password, use the CLI command set password. For more information, see Appendix A, "Command Line Interface."
Step 7 Reenter the new password.
The system checks the new password for strength. If the password does not contain enough different characters, you get prompted to enter a new password.
Step 8 After the system verifies the strength of the new password, the password gets reset, and you get prompted to press any key to exit the password reset utility.
http://www.cisco.com/univercd/cc/td/doc/product/voice/c_callmg/5_0/iptp_adm/504/iptpch2.htm#wp1040303
Hope this helps!
Rob
kgroves42 Thu, 11/01/2007 - 07:55
Does this work for the Security Password also, I know what the Admin Password is.
I am trying to add a server into the cluster but we don't have the security password, and the "set password security" requires the old password before you can change it.
Ken
mlitka Mon, 11/12/2007 - 16:42
I just performed the operation and it did have an option for the security password.
markus.thelen Thu, 12/06/2007 - 02:27
Hey Ken,
could you resolve the problem? I'm facing exactly the same problem as you had.
Hopefully there is another way than a clean install...
Cheers,
markus
kgroves42 Thu, 12/06/2007 - 04:46
Yes this method does work
Password: pwreset
When you get to this step you will get an option to Change either the administrator password or the security password.
Ken
markus.thelen Thu, 12/06/2007 - 04:50
Thank you for your quick response. I tried it already direct from console. And I had to reboot my server first. He did not realize correctly, wether a CD/DVD was inserted or not.
Now we're fine again.
Cheers, markus
h.estigarribia Thu, 01/22/2009 - 13:08
Is it necessary to reboot the publisher server after reseting the security password? thanks
rob.huffman Thu, 01/22/2009 - 15:20
Hi Horacio,
The Publisher server will not require a re-boot after resetting the password :)
Hope this helps!
Rob
