Blocking streaming media with deep packet inspection
I have a problem with blocking streaming audio from web radio stations. We use a pair of ASA 5510's on our perimeter. Has anyone been successful at blocking this traffic with an ASA? If so could you provide a snippet of your configuration.
I assume it would be using Modular Policy Framework, but I have no clue how to write these from scratch, which is why im asking for help :)
Thanks in advance!!
Overall Rating: 5 (1 ratings)
didyap Fri, 09/28/2007 - 14:26
You can create a policy for blocking streaming traffic. Here is a sample
policy-map type inspect http Shareware
parameters
protocol-violation action drop-connection log
class asdm_high_security_methods
drop-connection
match request header non-ascii
drop-connection
match request uri regex _default_gnu-http-tunnel_arg
drop-connection log
match request uri regex _default_gnu-http-tunnel_uri
drop-connection log
match request uri regex _default_windows-media-player-tunnel
drop-connection log
acomiskey Fri, 10/19/2007 - 11:18
didyap,
I tried out your config example and cannot get it entered. Could you help me out?
ASA5510(config-pmap-p)# class asdm_high_security_methods
ERROR: % class-map asdm_high_security_methods not configured
If I go back and do...
ASA5510(config)# class asdm_high_security_methods
then go back and try...
ERROR: Specified class type is different from the policy-map type.
