Hello
At the moment I have an office that has a 1751v with two FXO ports for buisness lines, and VG200 with two DID ports for direct calls.
I'm looking to upgrade to a PRI and have the 1751v handle both of those services via the PRI/T1 card.
There shouldn't be any conflict of service there should there? It's just a matter of router configuration correct? Meaning, since the phone company is putting both services on a single circuit, the router with the single PRI card should be able to handle both simultaneous right?
That's probably a stupid question, I just wanna make sure I'm not over looking something..
Thanks for any advice.
