remote access with 3845
Answered Question
Sep 24th, 2007
i want a confirmation that Cisco 3845 ISR with NM-16AM-V2 and NM-1CE1T1-PRI card can be configured as a remote access serveur in order to permit remote client access through isdn and pstn.
Correct Answer by Paolo Bevilacqua about 9 years 4 months ago
For modem access via PRI you also need PVDM2-DMxx where x is the number of simultaneous calls you need (avail 8, 16 and 32).
The NM-16AM-V2 instead has internal modems using analog lines and is not needed if using PRI exclusively.
Overall Rating: 5 (1 ratings)
Correct Answer
Paolo Bevilacqua Mon, 09/24/2007 - 14:32
