09-24-2007 12:47 PM - edited 03-14-2019 11:42 PM
Is there a way to find all the office directory numbers or list in Callmanager?
Solved! Go to Solution.
09-24-2007 01:14 PM
Hi Jose,
Have you tried using this report;
Route Plan Report
The route plan report lists all assigned and unassigned directory numbers (DN), call park numbers, call pickup numbers, conference numbers, route patterns, translation patterns, message-waiting indicators, voice mail ports, and Cisco CallManager Attendant Console pilot numbers in the system. The route plan report allows you to view either a partial or full list and to go directly to the associated configuration windows by clicking the Pattern/Directory Number, Partition, or Route Detail fields.
In addition, the route plan report allows you to save report data into a .csv file that you can import into other applications. The .csv file contains more detailed information than the web pages, including directory numbers for phones, route patterns, pattern usage, device name, and device description.
From this good doc;
Hope this helps!
Rob
09-24-2007 01:14 PM
Hi Jose,
Route Plan Report
From this good doc;
Hope this helps!
Rob
09-24-2007 01:17 PM
Damn you're good!!!
Thank you!
09-24-2007 01:21 PM
Hi Jose,
Thank you for your very kind words:)
Take care,
Rob
09-24-2007 01:24 PM
You're welcome. You've answered several questions I've asked in the past.
J.
