Software Update Problem
Answered Question
Sep 24th, 2007
I'm trying to make a backup of a production 2610 router, and would like to update the software on the spare router using TFTP server on a PC connected via a cross-over cable. IP addresses are set on both the router's ethernet 0/0 interface and the PC, however I can ping the router from the PC,but can't ping the PC from the router. Is there a command I'm missing, or just basic networking stuff I'm forgetting?
Correct Answer by Jon Marshall about 9 years 4 months ago
Could you just check that you do not have a firewall on your PC that could be blocking the pings from the router.
Jon
Overall Rating: 5 (1 ratings)
Correct Answer
Jon Marshall Mon, 09/24/2007 - 13:21
Jon
Richard Burts Mon, 09/24/2007 - 13:46
I agree with Jon that the most common cause of problems like this is a firewall running on the PC. If it is not a firewall issue then I would suggest checking the mask configured on the PC and make sure that it agrees with the mask on the router.
Rick
dlitteer Tue, 09/25/2007 - 04:11
Good lord. That was it. Talk about overthinking yourself right out of a solution. Thanks for your help Jon.
