ASA Traffic Shaping
Sep 24th, 2007
Are there any commands for shaping traffic on the ASA? I have found the police command but none on shaping.
amritpatek Fri, 09/28/2007 - 14:32
You can use priority queuing for traffic shaping. Priority Queuing is going to be typically used to provide low-latency voice/video service. To enable it, you match the traffic you want to be priority queued with a 'class-map'. Then you apply the class-map to a 'policy-map' that you set the action to 'priority'. Following link may help you
