pagp/lacp over multiple switches
Answered Question
Sep 24th, 2007
Hi All
Is it possible to configure pagp or lacp channels using more than one switch ie with 2 switches connected together (not in a stack) and using a port on each create a etherchannel? I have a requirement to diversify links but would like to channel the links up to get better bandwidth utilization.
Correct Answer by ankbhasi about 9 years 5 months ago
HI Nhon,
If your requirement is this
sw1 (port 1)---(port 1) sw2
sw1 (port 2)---(port 2) sw2
it is very much possible and this is the way etherchannel muct be use.
But if your requirement is
sw1 (port 1)----(port 1) sw3
sw2 (port 1)----(port 2) sw3
this is not possible as of now as etherchannel cannot be split between 2 switches.
Ankur
*Pls rate all helpfull post
Overall Rating: 4 (1 ratings)
Correct Answer
ankbhasi Mon, 09/24/2007 - 21:21
HI Nhon,
Ankur
