ISP Failover in Router
Sep 24th, 2007
hi ,
we are using 1841 cisco router with IPbase 12.4c as the image in the router and we have configured NAT with ip nat inside and ip nat outside in fa0/1 & serila0/0/0 .Now we want to use other broadband connection as a failover in fa0/0. Can we do that? if yes...plzs provide me with the configuration .its ugrent..
the following is the configuration...
Ds#sh runn
Ds#sh running-config
Building configuration...
Current configuration : 1116 bytes
version 12.4
hostname Ds
boot-start-marker
boot-end-marker
enable secret xxx
no aaa new-model
resource policy
mmi polling-interval 60
no mmi auto-configure
no mmi pvc
mmi snmp-timeout 180
ip subnet-zero
ip cef
no ip dhcp use vrf connected
ip name-server 209.x.x.164
ip name-server 207.x.x.5
username cisco password 0 XXXXXXX
interface FastEthernet0/0
shutdown
duplex auto
speed auto
interface FastEthernet0/1
ip address 192.168.1.1 255.255.255.0 secondary
ip address 247.x.x.1 255.255.255.145
ip nat inside
duplex auto
speed auto
interface Serial0/0/0
ip address 50.x.x.12 255.255.255.252
ip nat outside
ip classless
ip route 0.0.0.0 0.0.0.0 Serial0/0/0
ip http server
ip nat inside source list 1 interface FastEthernet0/1 overload
access-list 1 permit any
control-plane
line con 0
line aux 0
line vty 0 4
password XXXX
login local
end
Dsource#
gaurav_thapar79 Tue, 09/25/2007 - 11:41
Create route-map policies and then use them in NATTing.. This would help NAT to actually decide the exit path incase of failure.Definitely the source IP address 'll get changed in case of multihoming.
mathurmahesh Wed, 09/26/2007 - 07:37
can you give me the configuration for it?
lets say the secondary wan ip (fa0/0): 122.25.26.23/24
gateway: 122.25.26.1
plzs give the configuration
Thanks in advance.
