Aironet 1200 Interface changed state to reset
Sep 24th, 2007
I have used the command snmpset to change the properties of my ap.
After that, i got the following message:
Notification: Interface Dot11Radio0, changed state to reset.
When the AP resets its state, all the clients are disconnected.
How can i avoid the reset of the AP?
I want to make changes dynamically - and also i want my clients to maintain their connection.
irisrios Mon, 10/01/2007 - 08:21
When changes are mode to AP it is bound to restart for the new changes to take effect. But it shouldn't reset. Then this is probably an issue with the firmware. Try to reset the AP using Mode button . Before you do this back up your configurations. Last resort would be to upgrade the AP.
theodionys Thu, 12/06/2007 - 05:21
Hello again,
Yes it's my mistake,the AP restarts for the new changes to take effect.It doesnt reset.
Particularly i change the MAX Association number of the clients using SNMP.
When i do this the AP disconnects all the clients!
Is it necessary or i have a wrong firmware version.
Trending Topics - Security & Network
