How to change time format in IPM 2.6
Sep 25th, 2007
HI.
I am in India and if i try to generate a report from the IPM client, the time range shown is IST. If i try to generate the same report through Web Client, it is generating the same in GMT. I would like to change this to IST..Please let me know if this is possible. Sample report output is attached
ebreniz Mon, 10/01/2007 - 06:46
You must be logged in as the root user (Solaris) or administrator (Windows) to use export IPM data using the ipm export command.
Format:
Time - and need to be input as
MM/DD/YYYY-hh:mm:ss
Date - needs to be input as:
MM/DD/YYYY
and need to be input as:
MM/DD/YYYY
for more information http://www.cisco.com/en/US/products/sw/cscowork/ps1008/products_user_guide_chapter09186a0080368f68.html#wp1007017
Please rate the post
