Compatibility Cisco GLC-BX and MediaConverter AlliedTelesis
Sep 25th, 2007
Goodmorning to everyone.
We need you help about the GLC-BX SFP compatibility with the Media Converter
Allied Telesis AT-MC1008/SP.
In particular we want to try the Cisco GLC-BX with AT-MC1008/SP (1Gbps ethernet trasmission on one single fibre).
Are there anyone formerly use this solution?
Can we consider AT-MC1008/SP and GLC-BX compatible?
Or there are problems?
Thank you very much.
htarra Mon, 10/01/2007 - 06:55
  • Bronze, 100 points or more
If they are both media type LX they should work. You can replaced the AT-SPLX10 Allied Telesysn SFP on the MC with the cisco SFP.
pbenin Mon, 10/01/2007 - 06:58
And if both media type is BX?
(one Cisco GLC-BX in ATI MC and the other one in a CiscoRouter or Switch)
Thx
