Access List Probz
Sep 25th, 2007
  • Silver, 250 points or more
i have access-list problem, my requirement is i wanted to permit 61.1.1.48 to access a public IP 202.1.1.1, which is a FTP server. so i have permitted ONLY FTP access outside for 61.1.1.48.where as other ip address in the same series 61.1.1.0/24 they are permitted to access any ports outside.
interface serial 0/0/0
ip address 1.1.1.1 255.255.255.252
ip access-group 101 out
ip access-group 102 in
interface fas 0/0
ip address 61.1.1.1 255.255.255.0
access-list 101 deny ip host 61.1.1.48 any
access-list 101 permit tcp host 61.1.1.1 host 202.1.1.1 eq 21
access-list 101 permit ip any any
access-list 102 permit ip any any
when i issue this in my router, i get this message. when i do ftp to 202.1.1.1 from 61.1.1.48
C:\>ftp 202.1.1.1
Connected to 202.1.1.1.
Connection closed by remote host.
please correct me where ever i have done mistake on this.
Overall Rating: 5 (1 ratings)
Jon Marshall Tue, 09/25/2007 - 05:06
  • Hall of Fame,
    Founding Member
  • Cisco Designated VIP,
    2017 LAN, WAN
Can you recheck your acl 101 ie.
1) your first line denies 61.1.1.48 from any access so it doesn't matter what else is in the acl.
2) Is line 2 meant to say 61.1.1.148 instead of 61.1.1.1 ?
If so you need to update the line and move it to the top of the acl.
Jon
Anand Narayana Tue, 09/25/2007 - 05:08
sorry it was actually 61.1.1.48 only, it was my mistake while typing in this form.
access-list 101 permit tcp host 61.1.1.48 host 202.1.1.1 eq 21
Jon Marshall Tue, 09/25/2007 - 05:11
  • Hall of Fame,
    Founding Member
    2017 LAN, WAN
You still have the same problem with the order of your acl lines.
The first line denies ip from that 61.1.1.148. IP includes tcp and udp so it will never get to the second line.
Jon
Anand Narayana Tue, 09/25/2007 - 05:14
yeah i still face the same probz,
you wanted me to try adding the UDP also?
Jon Marshall Tue, 09/25/2007 - 05:19
  • Hall of Fame,
    Founding Member
    2017 LAN, WAN
No you should need udp for ftp.
Could you send updated access-list. Remember that ftp uses more than just one port and you have only allowed one port through. Try adding TCP port 20 as well as TCP port 21 to your acl.
This still may not work - do you know which kind of FTP you are using, active or passive ?
Jon
Anand Narayana Tue, 09/25/2007 - 05:23
i tried with GUI FTP client(Filezilla) which is by default in PASSIVE mode.
so shall i go head with the below ACL?
access-list 101 permit tcp host 61.1.1.48 host 202.1.1.1 eq 20
if so, then i will go head in putting this ACL in my router .
Jon Marshall Tue, 09/25/2007 - 05:29
  • Hall of Fame,
    Founding Member
    2017 LAN, WAN
Try this and let me know result. Note that i have reordered lines.
Jon
Anand Narayana Tue, 09/25/2007 - 05:38
k fine will try & let you know ny tomorrow, as the remote end every one has left for the day.
Jon Marshall Tue, 09/25/2007 - 05:47
  • Hall of Fame,
    Founding Member
    2017 LAN, WAN
Okay no problem.
Had a quick check on passive mode. If the access-list you have doesn't work try
access-list 101 permit tcp host 61.1.1.48 host 202.1.1.1 range 1025 65535
Jon
Anand Narayana Thu, 09/27/2007 - 03:56
Hi Marshall,
it was extremelly helpfull & it worked out with this command itself, thankz for valuable response.
