Attendant Console 6.0(1), getting caller ID number, but not displaying name
Our receptionist has Attendant Console v6.0(1) and our call manager is v6.x. When a call comes in our PRI she can indeed see the name and number on the attached phone display, BUT the attendant console ONLY shows the number. How do you get the Attendant Console to show both the number and the caller id name?
Thank you.
Overall Rating: 5 (1 ratings)
gogasca Tue, 09/25/2007 - 08:50
  • Green, 3000 points or more
Mmm I remember that was a limitation in previous version.
And was overcome configuring speeddials.
For example if you get plenty of calls from Company XYX configure the speed dial that matches the callerId and test.
I would think using speed dials to overcome this is not a permanent solution since there WILL still be many, many calls without the caller name. If the phone itself receives it why not have the Attendant Console display it as well? In my mind this is a simple development issue that could be addressed... and should be addressed. Without this info readily available in the incoming call area the receptionists at times can't remember which call is for who because it only shows the number.
joeharb Thu, 07/24/2008 - 08:51
I am running into the same issue...if the incoming call has Calling Name the phone shows it fine...the ac doesn't...if the incoming call only has the calling number the ac displays this fine....Is there any fix to this?
Joe
