asa to netscreen with dynamic IP
Sep 25th, 2007
Hi, has anyone set up a l2l vpn to a netscreen 5xp which uses a dynamic address? we are using one with a dynamic cryto map configured on the pix and aggressive mode on the netscreen, the pix is trying to authenticate the netscreen against the defaultRAGroup not the group set up for this connection. I have seen a similar problem posted here but with no solution other than getting the client to use a static IP. Here are the relevant config bits, thanks in advance.
tunnel-group netscreen type ipsec-l2l
tunnel-group netscreen ipsec-attributes
pre-shared-key *
crypto dynamic-map L2LDYN-MAP 10 match address IPSEC-netscreen
crypto dynamic-map L2LDYN-MAP 10 set pfs
crypto dynamic-map L2LDYN-MAP 10 set transform-set DYN-SET
crypto dynamic-map L2LDYN-MAP 10 set security-association lifetime seconds 3600
crypto ipsec transform-set DYN-SET esp-3des esp-sha-hmac
crypto isakmp policy 20
authentication pre-share
encryption 3des
hash sha
group 2
lifetime 3600
