2821 VWIC2-2MFT-T1/E1 line up, protocol down
Sep 25th, 2007
I?m replacing a 2621 with VWIC-2MFT-T1 cards and going to a 2821 with VWIC2-2MFT-T1/E1 cards.
When I do the cut-over all of my serial interfaces are showing up, line protocol is down.
All of my existing routers have the older vwic-2mft-t1 cards. My new configuration is a copy of my old 2621 config, so I don?t see where the problem lies.
I?d like to try swapping out the router again this weekend, but I?m not sure what is causing the protocol to be down. Any ideas?
controller T1 0/0/0
framing esf
linecode b8zs
channel-group 0 timeslots 1-24
controller T1 0/0/1
framing esf
clock source internal
linecode b8zs
controller T1 0/1/0
framing esf
linecode b8zs
controller T1 0/1/1
framing esf
linecode b8zs
interface Serial0/0/0:0
description Serial Interface to Berkeley
ip address 10.35.2.1 255.255.255.252
ip access-group 101 in
ip pim sparse-dense-mode
encapsulation ppp
ip route-cache flow
ip summary-address eigrp 100 10.0.0.0 255.0.0.0 5
ip summary-address eigrp 100 1.0.0.0 255.0.0.0 5
ip mroute-cache
fair-queue
interface Serial0/0/1:0
no ip address
interface Serial0/1/0:0
description Serial Interface to Glendale
ip address 10.35.3.1 255.255.255.252
ip directed-broadcast
encapsulation ppp
ip route-cache flow
ip mroute-cache
ppp authentication chap
interface Serial0/1/1:0
description Serial Interface to Cypress
ip address 10.35.4.1 255.255.255.252
encapsulation ppp
ip route-cache flow
ip mroute-cache
fair-queue
Richard Burts Tue, 09/25/2007 - 08:09
Rob
This post duplicates the information that you posted in the thread called two T1 lines in this same forum. You injected your question into that thread yesterday and I suggested that posting config details would be helpful. This morning you started this current thread and then you posted the same config in the other thread. It would have been much better to have just responded in the other thread that you were starting a new thread (which is quite appropriate) than to try to maintain two parallel threads within the same forum.
I have posted my response in the other thread. Where do you want any continuing discussion to be held?
Rick
robwagner Tue, 09/25/2007 - 08:19
Sorry Rick.
I posted this thread first thing this morning, then went and saw you posted a response to my question in the other thread.
My appoligies...
