Mail Flow Central Log Issues
Sep 25th, 2007
I am getting the following error, anyone got any ideas?
Log Error: Push error for subscription MailFlowCentralLogs: An FTP command failed to.......(and then the server its trying to access)
The server is up and running, as is MFC.
Cheers
pvdberg00 Tue, 09/25/2007 - 09:18
Where is the error displayed (on the Ironport server or on the MFC server)?
Is your Ironport server or MFC server busy with doing something (a large workqueue or the daily purge)?
pvdberg00 Tue, 09/25/2007 - 09:26
If this error message is just for one time I think you can ignore the message. Otherwise you have a problem with receiving the MFC server. It can be a network problem or your server is to busy to accept.
pvdberg00 Tue, 09/25/2007 - 09:28
asw_26_ironport Tue, 09/25/2007 - 09:29
It has been happening since around midnight. However I have received no errors for around 40 mins, looks like it may have cleared itself.
Cheers anyway.
Mark [CSE]_ironport Tue, 09/25/2007 - 13:31
I guess there are no firewall in between that got changes since midnight?
Does a normal ftp client work from the windows server to the IronPort, with file download?
Cheers,
Mark
asw_26_ironport Tue, 09/25/2007 - 14:33
Hi there, it appears to be a diskspace issue, we have been cleared down our logs but the SQL DB obviosuly builds up and up, so we are now going to attempt to compact it.
Cheers for ur help.
