Prevent SRST GW from Registering E.164 to GK
Sep 25th, 2007
Hi, guys,
I was trying to prevent SRST GW from registering E.164 address to GK with 'dialplan-pattern' command under Call-manager-fallback with 'no-reg' parameter, but failed. It still registers.
I am using 10 digit ext. in CCM. So I configure:
dialplan-pattern 1 T extension-length 10 no-reg
I really do not understand why it does not work. Is there any other way to turn off e.164 registering?
Thanks for your help.
Soup
Overall Rating: 4 (1 ratings)
umedryk Mon, 10/01/2007 - 14:22
  • Bronze, 100 points or more
Th no reg option at the end of the command prompt will prevent SRST GW from Registering
call-manager-fallback
dialplan-pattern tag pattern extension-length length [extension-pattern extension-pattern] [no-reg]
Jon Nelson Mon, 10/01/2007 - 18:18
  • Silver, 250 points or more
Another thing to keeep in mind is that if you put the dialplan pattern command in once without no-reg it will still try and register with the gatekeeper unless you delete the dialplan-pattern and reload the router and then type the command in again.
Thank you,
Jon
soupseven Thu, 10/04/2007 - 09:51
Thanks a lot,
That might be the trick, or a bug. I did reload the router, but with that command and it did not help. I will try it later when I have chance. Now since it is already in production, it is harder to do testing.
Soup
