Restore Config File
Sep 25th, 2007
I need alittle clarification on restoring a config via tftp.
I have a PIX 506e running 6.3
I am using the configure net command to upload a new config file to the pix from a tftp server. This command is merging the two files but, I need to over write the current config file with the new one.
what command is needed to restore the config via tftp and overwrite the old one?
Thanks in advance.
Richard Burts Tue, 09/25/2007 - 09:49
  • Hall of Fame,
    Founding Member
  • Cisco Designated VIP,
    2017 LAN, WAN
Eddie
I have not done this on a PIX so I can not speak from experience. But I believe that the process on the PIX is like the process with IOS. When you tftp to running-config it is a merge operation of the new file and the existing file. so you should tftp to startup-config which is a replace operation of the old file. Then you reboot to load the restored file.
Rick
eddiecain Tue, 09/25/2007 - 10:05
Rick,
The command copy tftp startup-config
doesn't work with pix.
Thanks.
