PIX 515e VPN client access isue
Sep 25th, 2007
we have pix515e, ver 7.0(4). We have made access through cisco vpn clinet for our clients. Radius server is placed in our inside network. everything is working fine for 4 days, after that we need to reload the pix. When the problem start, user is getting the message: "Remote peer no longer responds". Does anyone have that kind of problem.
Thanks Nemanja
ivillegas Mon, 10/01/2007 - 11:02
  • Silver, 250 points or more
Make sure the PIX is not blocking UDP traffic 500.
nemanja.stosic Tue, 10/02/2007 - 02:17
I have said that everything is workig fine for 4 or 5 days, that means that udp 500 is not blocked. After that time, pix just stop responding to cisco vpn clinet requests.
Regards Nemanja
cswenson Tue, 10/02/2007 - 09:08
I have had that problem too upgrade too 7.2.(X) and it was solved.
nemanja.stosic Tue, 10/02/2007 - 22:27
Hi, thanks for reply, do you know what was cosing this kind of problem.
Best regards Nemanja
cswenson Tue, 10/02/2007 - 23:26
No somehow it stops prcessing IKE i tried to find something about it in open caveats but no success.
Trending Topics - Security & Network
