Restrict DID number based on caller id
Sep 25th, 2007
A customer has a couple of DID numbers. He want's to restrict the ability to call the numbers based on the caller.
Example:
Employee A has DID 123 and can only been called by number +3161234556. Other number cannot call employee directly. He also want to be able to add multiple numbers who can call employee A directly.
The customer has CUCM version 6 and a h323 gateway.
Abdulbaseer Mohammed Sat, 09/29/2007 - 20:34
Sebastian,
This is easy if they have IPCC xpress or enterprise.
The other option do they have any pattern to DID and or the caller numbers?
Baseer.
