Sending digits dialed from an application to IP Communicator
Sep 25th, 2007
Is there a way to develop a method to send dialed digits from an application to IP Communicator. Basically looking for a way to integrate an open systems application to use IP communicator as it's dialer/phone. Thank you in advance.
Overall Rating: 5 (1 ratings)
pklos Tue, 09/25/2007 - 10:35
You can send dialed digits from application to every phone using TAPI/JTAPI integration.
regrads,
pk
johnnywan Tue, 09/25/2007 - 11:00
Yes sir, and thank you. Not being familiar as I should with Call Manager Express - will TAPI/JTAPI still be an option?
pklos Tue, 09/25/2007 - 11:30
For CME you can still use TAPI. Look for proper Cisco TSP.
regards,
pk
ps. please rate this post if helps.
