RME:Config Archive
Sep 25th, 2007
I have 7 Partially Successful devices. The starting and running primary are successful. The Config Type:VLAN failed with the following error:
CM0012: Unable to create new version on archive$1 ACTION: Check if disk space is available and directory has required permissions
I did the ACTION and everything looks fine. I compared the failed devices with the successful devices and they look the same.
How do I fix this problem?
David Stanford Tue, 09/25/2007 - 11:09
  • Cisco Employee,
Posted on another thread earlier:
The CM0012 error is most likely caused by CSCsh39475. A patch is available on Cisco.com at http://www.cisco.com/cgi-bin/tablebuild.pl/cw2000-rme .
If, after applying this patch, you are still seeing errors, you should enable ArchiveMgmt debugging under RME > Admin > System Preferences > Loglevel Settings, reproduce the problem, then look at the dcmaservice.log for errors
