t3/e3 module
Sep 25th, 2007
Hello All,
Currently at corporate location, we have a router with a ATM A1-T3 module. I am in the process of migrating our circuit to AT&T MPLS and basically the new circuit from AT&T will be a T3 PPP circuit. The question to you guys is is the current module installed on the router compatible with the new circuit. Does this module support t3 PPP connection?
Gerald
paolo bevilacqua Tue, 09/25/2007 - 11:30
  • Hall of Fame,
    Founding Member
No. You need the serial T3 module.
