CCNA certification exam
Sep 25th, 2007
Hi everyone,
i want to take service provider CCNA exam.i am new to this field.what are the steps i should take to prepare for the exam? my ultimate goal is to take 642-611 on MPLS since i am very much interested in this field.the certification courses are very expensive.
thank you.
Overall Rating: 5 (1 ratings)
mark.j.hodge Wed, 09/26/2007 - 01:24
There is only one CCNA, they are not particular to any certificate path, details here
http://www.cisco.com/web/learning/le3/le2/le0/le9/learning_certification_type_home.html
As you are just starting out, I would recommend going for the updated version of the certicicate, 640-802, or the two step process. If you do go the two step route, then you would get an entry certificate CCENT.
The cost efficient way to gain these qualifications is to use self-study guides. The generaly recommended publications are from CiscoPress
http://www.ciscopress.com/bookstore/product.asp?isbn=1587201836
or Sybex
http://www.sybex.com/WileyCDA/SybexTitle/productCd-0470110082.html
** please rate posts if helpfull **
debasmita Fri, 09/28/2007 - 09:27
Thank You.
I ordered all CCNA books from cisco press.
they will be reaching within 4-5 days.
for lab practice what should i do?
