Cisco 1841 as router for 10MB Ethernet Data Service
Sep 25th, 2007
We are getting XO's 10MB Ethernet data service and I was wondering whether we can use our Cisco 1814 as the router for that service. The router has to interface with a Hatteras 408.
Dieter
Richard Burts Tue, 09/25/2007 - 13:21
  • Hall of Fame,
    Founding Member
  • Cisco Designated VIP,
    2017 LAN, WAN
Dieter
I do not have experience with XO's Ethernet data service and there may be things about it that would change the answer. But I would think that the 1841 router would do ok. It certainly has the ability to handle Ethernet input (at higher data rates) and route it. I am assuming that the Hatteras does an Ethernet handoff which the 1841 should not have a problem with. A quick search did not turn up anything specific about the requirements for connectivity to the 408.
Rick
