2600 QSIG H.323 Gateway
Sep 25th, 2007
Hi - We have a a voice gateway which is being utilised for mobile calls. It is connected on E1 pri through PSTN to mobile company's ISDX using QSIG. We are utilising an existing 2600 H.323 gateway (config below) integrated with CCM 4.1. This has been workig fine in the past but now, although the calls connect - both parties calls connect, but the call is extremely distorted and only severe feedback is hear at both end.
Any help is greatly appreciated.
sho run
Building configuration...
Current configuration : 2647 bytes
! No configuration change since last restart
version 12.3
service timestamps debug datetime msec localtime
service timestamps log datetime msec localtime
hostname Voice_Gateway_Mobex
boot-start-marker
boot-end-marker
clock timezone GMT 1
voice-card 1
no aaa new-model
ip subnet-zero
no ftp-server write-enable
isdn switch-type primary-qsig
voice class codec 1
codec preference 1 g711ulaw
codec preference 2 g729br8
voice class h323 1
h225 timeout tcp establish 4
controller E1 1/0
framing NO-CRC4
pri-group timeslots 1-31
interface FastEthernet0/0
ip address 10.1.3.10 255.255.255.0
speed 100
full-duplex
h323-gateway voip bind srcaddr 10.1.3.10
interface FastEthernet0/1
no ip address
shutdown
duplex auto
speed auto
interface Serial1/0:15
no ip address
no logging event link-status
isdn incoming-voice voice
isdn contiguous-bchan
no cdp enable
router eigrp 999
network 10.1.3.0 0.0.0.255
no auto-summary
ip classless
ip route 0.0.0.0 0.0.0.0 10.1.5.1
ip http server
voice-port 1/0:15
cptone GB
dial-peer voice 10 voip
description ***VOIP Dial Peer to Secondary CCM - Calls to Mobex***
preference 10
incoming called-number 8....
voice-class codec 1
voice-class h323 1
session target ipv4:10.1.5.10
dtmf-relay h245-alphanumeric
ip qos dscp cs5 media
no vad
dial-peer voice 5 pots
preference 5
destination-pattern 80...
progress_ind alert enable 8
port 1/0:15
forward-digits all
prefix 1115
dial-peer voice 20 voip
description ***VOIP Dial Peer to Primary CCM - Calls to Mobex***
preference 5
voice-class codec 1
voice-class h323 1
session target ipv4:10.3.5.10
no vad
dial-peer voice 11 voip
description ***VOIP Dial Peer to Secondary CCM - Calls from Mobex***
preference 10
destination-pattern [2-4].....
progress_ind setup enable 3
voice-class codec 1
voice-class h323 1
no vad
dial-peer voice 21 voip
description ***VOIP Dial Peer to Primary CCM - Calls from Mobex***
preference 5
no vad
dial-peer voice 4 pots
preference 5
incoming called-number [2-4].....
port 1/0:15
forward-digits all
line con 0
password cisco
line aux 0
line vty 0 4
exec-timeout 0 0
password cisco
login
ntp clock-period 17209028
ntp server 10.1.5.10
end
Voice_Gateway_Mobex#
