Multicast moh on SRST router
Sep 25th, 2007
I am having a problem with this configuration. All seems to be configured correctly now but I still cannot hear the moh. Here is the configuration:
call-manager-fallback
max-conferences 8 gain -6
ip source-address 172.26.3.1 port 2000
max-ephones 48
max-dn 100 dual-line preference 2
moh Muzak_MOH_688808.ULAW.wav
multicast moh 239.2.1.1 port 16440 route 172.26.3.1 172.31.3.1
I have verified that the file is good and can be played. Here is the output of sh ccm music:
OCH903#sh ccm music
Current active multicast sessions : 1
Multicast RTP port Packets Call Codec Incoming
Address number in/out id Interface
239.2.1.1 16440 153/153 967 g711ulaw Lo0
OCH903#sh ccm music
239.2.1.1 16440 365/365 967 g711ulaw Lo0
OCH903#sh ccm music
239.2.1.1 16440 569/569 967 g711ulaw Lo0
So the packets are going in and out and are incrementing.
Any idea what could be wrong?
dezoconnor Wed, 09/26/2007 - 02:40
  • Silver, 250 points or more
You could try either:
1 - Bouncing the router, or
2 - Do a no ccm-manager music-on-hold
and under telephony-service delete
multicast moh 239.2.1.1 port 16440 route 172.26.3.1 172.31.3.1. Then re-enter all of the above again.
thisisshanky Wed, 09/26/2007 - 04:42
  • Purple, 4500 points or more
Also make sure you have
a. One music on hold source defined in Callmanager.
b. Codec used between MOH server and the remote region is g711 and not g729.
http://www.cisco.com/en/US/products/sw/iosswrel/ps5207/products_feature_guide09186a00802d1c31.html
Note that this streaming works only when wan connection is up and phones are registered to Callmanager.
Sankar
PS: please rememeber to rate posts!
VON CLAWSON Wed, 09/26/2007 - 06:14
Hey thisisshanky,
I have already created a moh region and DP. And the moh server is in that DP. Codec always comes up as g711 in the sh ccm music.
