nvram last config not displaying
Answered Question
Sep 25th, 2007
Hi Experts,
Is there any changes in the latest IOS version, as when I do " sh run" , the statements below are not displaying..
---examples----
! Last configuration change at 01:31:17 GMT Thu Aug 30 2007 by sasadm
! NVRAM config last updated at 01:31:59 GMT Thu Aug 30 2007 by sasadm
Thus, I wont be able to know who did the changes on the router..
Correct Answer by Richard Burts about 9 years 4 months ago
Cindy
This is an interesting problem with a simple solution. If the router believes that it really knows the correct time and date (either it has the calendar chip, it is running ntp and has learned time, or has executed clock set) then it will put those lines into the config. And if the router does not believe that it really knows the correct time then it does not put those lines.
My suggestion is to get correct time into the router (ntp or clock set), then make a config change, and then look at show run and see if the lines do not show up again.
Rick
Overall Rating: 5 (3 ratings)
Correct Answer
Richard Burts Wed, 09/26/2007 - 07:27
Cindy
Rick
cindylee27 Thu, 09/27/2007 - 20:46
Hi Rick,
Sorry for the late reply..You are indeed very right..:)
it was due to the ntp md5 password was mismatch..change that and it works like a charm..
But this brings me to another issue..
Well, My Core Switch able to sync with the Core Router but my dist sw not able to sync with the Core Switch. Any problems with the config below?
I did a sh ntp status as well..Any more info u need can let me know..
Thanks..
Distribution Sw Configuration
interface Vlan1
no ip address
no ip redirects
no ip proxy-arp
no ip route-cache
shutdown
ntp broadcast client
interface Vlan3
ip address 15.12.3.1 255.255.255.0
no ip redirects
no ip proxy-arp
no ip route-cache
ntp authentication-key 888 md5 4444C124B7A10401C1432 7
ntp authenticate
ntp trusted-key 888
end
SGDistSW#sh ntp status
Clock is unsynchronized, stratum 16, no reference clock
nominal freq is 119.2092 Hz, actual freq is 119.2092 Hz, precision is 2**18
reference time is 00000000.00000000 (00:00:00.000 GMT Mon Jan 1 1900)
clock offset is 0.0000 msec, root delay is 0.00 msec
root dispersion is 0.00 msec, peer dispersion is 0.00 msec
Core Sw Configuration
interface Vlan3
ip address 15.12.3.253 255.255.255.0
ip access-group 103 in
ip access-group 103 out
no ip redirects
no ip proxy-arp
ntp broadcast key 888
standby 3 ip 15.12.3.254
standby 3 priority 130
standby 3 preempt
ntp authentication-key 888 md5 1111383508155517101234 7
ntp authenticate
ntp trusted-key 888
ntp clock-period 36028921
ntp source Loopback0
ntp server 15.12.255.221 key 888
ntp server 15.13.255.249 key 888 prefer
end
SGCoreSW#sh ntp status
Clock is synchronized, stratum 7, reference is 15.13.255.249
nominal freq is 119.2092 Hz, actual freq is 119.2088 Hz, precision is 2**18
reference time is CAA7049B.6BE2D47B (04:42:03.421 GMT Fri Sep 28 2007)
clock offset is 5.6022 msec, root delay is 40.53 msec
root dispersion is 140.29 msec, peer dispersion is 2.79 msec
Richard Burts Fri, 09/28/2007 - 05:35
Cindy
I do not see anything on the distribution switch that tells it what to request time from. I suggest that you add this to the switch config and let us know how it works:
ntp server 15.12.3.253
Rick
cindylee27 Sun, 09/30/2007 - 04:23
Thanks Rick..
I tried ur method n took it out after that.. It works like a charm.. believe that the time drift too far away thats y the ntp not able to do sync..
Now is working.. :) thanks a lot!
Richard Burts Sun, 09/30/2007 - 11:15
Cindy
I am glad that you got it working. Thank you for posting back to this thread and indicating that you had resolved the issue. It makes the forum more useful when people can read about an issue and can know what suggestion led to resolution of the issue.
Rick
uubozou11 Mon, 10/01/2007 - 09:00
On that note, how does an author mark his/her post as solved?
Richard Burts Mon, 10/01/2007 - 09:16
Jimmy
The easy part of the answer is that if you are the author/origin of the thread there is a box that you can check on each of the posts that other people have made. If you select that box on the post that helped you solve your problem then it marks the thread as solved.
It is a somewhat different situation if you are the author/origin of a thread and if you find your own solution so there is not someone else's post that you can check the box. I do not believe that there is any ability to check your own ratings. I am not sure what you would do to mark it as solved if you can not attribute the solution to someone else.
Rick
