7961G with Expansion Module 7914
elkono200
hi,
a simple question.
i will buy a 7961G phone with an expansion module 7914. The 7961G will be powered with PoE. i cannot find out if its possible to connect the module without an external power cube if i power the phone with PoE.
thx
Hey Paolo,
Here is the breakdown I have always used;
Cisco Unified IP Phone Expansion Modules 7914
Cisco 7960 Power Source
Items to Order
1 7914 with 7960 with In-line PoE (you need to order the following)
One, Cisco Unified IP Phone Expansion Module 7914
One, single footstand
One, power cube
One, country cord
1 7914 with 7960 with Local power (cube)* (you need to order the following)
2 7914's with 7960 with In-line or local power** (you need to order the following)
Two, Cisco Unified IP Phone Expansion Module 7914 ExpansionModule
One, double footstand
One, power cube
One, country cord
* A single Cisco Unified IP Phone Expansion Module 7914 can receive power from a locally-powered (power cube) Cisco Unified IP Phone.
** Local power must be connected to the first Cisco Unified IP Phone Expansion Module 7914. This supplies power to both Cisco Unified IP Phone Expansion Modules 7914s.
From this excellent doc;
http://www.cisco.com/en/US/products/hw/phones/ps379/products_data_sheet09186a008008883d.html
Hope this helps!
Rob
PS: Nice to have you back from your TROUBLESHOOTING TRAVELS!
icabrera
Level 4
Level 4
Hi, take a look at the next url:
You can see a table with the power requeriments, if you have a 7961G with PoE you'll need an external power cube for the 7914 module to work.
Regards.
Hope this helps, if so pls rate post
thx. now i know what i have to buy.
Actually, the first additional module will power with Poe from the phone. If you have a second 7914, that will require a separate power cube.
Hey Paolo,
Items to Order
One, power cube
One, country cord
One, power cube
One, country cord
Hope this helps!
Rob
