Bandwidth Monitoring Software
Sep 25th, 2007
Hi!
is there any software or tool that can give exact bandwidth usage? im using netflow now but it seems that it doesnt detect the exact bandwidth on my serial interface. if someone knows. please post it.
tnx a lot
jacobss914 Thu, 09/27/2007 - 07:12
Solarwinds if you have the $$$$ for it. Engineer's tool edition will work for a short while it is MSDE based ( limited records) Orion if you need true robustness and long term data.
Not sure how close to exact thou cause you would have to turn up the polling. You could easily cripple your information with intervals to close together. This will cause false positives, and erratic behavior. But it does a nice job of keeping fairly accurate traffic information.
