How to check the ccapi disconnect cause?
Sep 25th, 2007
Hi Forums,
I tried to call a destination number but failed.
I have this message logged using the debug voice ccapi inout, I tried to search for the disconnect cause, however I cant find it. Would really appreciate if anyone can help.
Sep 26 06:05:18.204: //253129/469D3310BBED/CCAPI/ccCallSetupRequest:
: Destination Pattern=66T, Called Number=66035277000, Digit Strip=FALSE
.Sep 26 06:05:28.440: //253129/469D3310BBED/CCAPI/ccCallDisconnect:
Cause Value=16, Tag=0x0, Call Entry(Previous Disconnect Cause=0, Disconnect Cause=0)
Thanks much,
Overall Rating: 4.8 (5 ratings)
cristian.munoz Wed, 09/26/2007 - 07:48
Dear Paul
Use the ISDN Cause Code, for CCAPI and ISDN are the same.
In this case : Cause Value=16 , 16 is Hexa and the table show :Number changed. The ISDN number used to set up the call is
not assigned to any system.
If you want, i can send to you a pdf with the table.
paulnigel Wed, 09/26/2007 - 23:04
Hi Christian, icabrera,
Thank you very much for your assistance. I am trying to read through the document.
Christian, I would be pleased if you can send me the ISDN cause code in PDF.
Thanks much,
