RightFAX
Sep 26th, 2007
Yelp!
We are ripping out the PBX and its currently providing ISDN connectivity to our RightFax server.
Calls come into a PRI and get delivered to the Brooktrout TR1034+P4-2B from a card in the PBX.
We've ordered a BRI card for a 3845. At this point we get no connection between the server and router.
Has anyone done this before?
As an added twist, we are setting this up in Germany.
Any input greatly appreciated. We are cutting over on Friday.
Thanks!
-Erik
Overall Rating: 5 (1 ratings)
ecstillman Fri, 09/28/2007 - 07:08
A BRI crossover did the trick! 3 > 5 , 4 > 6.
Easily available if you search Cisco.com
-Erik
sjones226 Mon, 10/01/2007 - 12:48
Erik,
Are you taking on this RightFax project by yourself, or have you found resources to assist you? We are looking for similar resources.
Steve
JoshMiller Wed, 03/11/2009 - 11:11
Hi Erik - out of curiosity what BRI card were you using?
stafford.slater Sun, 11/22/2009 - 04:49
I have set this up sucessfully using the crossover as mentioned attached is documentation for setting up under H323.
If you are using MGCP enter the commands as detailed in the document under the BRI and also ensure you set the clocking on the E1 connected to PSTN
network-clock-participate wic 0
network-clock-select 1 E1 0/0/0.
show network-clocks
Once you have done this issue no MGCP and then MGCP.
Cheers
